Seiko 7S26 amplitude
Hello,
I recently serviced Seiko 7009 with 7S26 movement. Watch was general in poor condition, movement was dirty and there was no oil on jewels. Timegrapher had dificculty to read the amplitude and beat error but visually amplitude was very low. I took it on my bench, cleaned and oiled with Novostar B oil. After that amplitude wasn't satisfactory circa 200deg. I read on net that this movement has generaly problem with amplitude. Besides it get quite good accuracy I could leave it but... I took a look of the balance hairspring - little bented and I think there could be problem. I don't have too much experience and skills with work on the hairspring but I tried to get it better shape. It took me almost 2 hours and I had to take off the hairspring few times. It's not perfect shaped hairspring now but it's better then it was. After that I put the movement on the time machine, look guys what I managed to achieve.
Glass up
Glass down
I think it's quite good right now. I decided to leave it at this moment. What do You think? Is the Novostar B is right oil for this caliber for everywhere use? Should  pallet fork jewels be lubricated or only the pallets? I'm looking forward Your opinion cause I am a beginner and aprecciate good advices. Thanks
There are very many threads which report this problem, it is common with old 7S26. I recommend that you heavily use the search function, to find about that and more  e.g.. that you never oil the escape wheel pivots, that you need (at very least) two types of lubricant, etc.
About your specific problem you will read even after my posting here about the usual suspects, some a
  • imperfect dirty or magnetized HS (in reality magnetized HS doesn't cause poor amplitude, but there is always someone that will suggest that anyway)
  • dirty balance jewels
  • bent balance pivots
  • too tight balance handshake
  • weak mainspring
You may also read that the fault is because of something you do wrong, and these Seiko can be made oscillate 300°. I disagree with both points.
I can instead ensure you that there is a very high possibility that you go over these points for many hours without applicabile improvement. Replacing balance complete may give you better chances, but that is (relatively) expensive if bought new and original compared to a new mov"t with hack and manual winding for little more.
Finally, PC timegrapher is great but if you show waveform only one can't see the overall pattern, that is the screws with two lines which should be close, continuous and horizontal, so you need to post these.
Nitpick, the horizontal main positions are called dial up (DU) and dial down (DD). The others are relative to crown (sometime 12h ) position, like crown up, etc. You need to always test at least crown down.
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
    • The original database is available on iOS devices here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
