I wonder is there another way of trying to buy a piece from cousins. The part I need is a pull out piece screw. I have searched cousins for the part and even searched for pullout piece and screw no results. Is there another term for pull out piece and screw? It's the shoulder for the plate I need.
Cheers
Gary
  • oldhippy changed the title to keyless part
I'm not sure. The only thing I can think of if the movement is fitted with say calendar or day/date or both, sometimes another number would be added. You could phone them and ask.
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
