Hi guy’s! I’m looking for a main barrel for a swiss watch, can anyone help me find a replacement! All I’ve got is it’s dimensions! Cheers!IMG_0480.jpg
I think you will have better chances by posting front and back pictures of the mov't to identify what it is.
Will also need a picture of the front with the dial removed.
Also you should remove the balance, as the maker marking may be there.
Edited by jdm
There you have it, FHF 175, Cousins has all the barrel parts.
If you wonder, the index markings were for timing at the factory, before the timegrapher was invented or universally adopted.
7 minutes ago, Nucejoe said:
FHF175 says so right on the mainplate.
Typical for an ebauche maker to mark on the place less likely to be seen by a curious watch owner.
