Hi all
First time servicing an old EB 8080.
Any idea if I should be removing this wheel before putting in the cleaning machine? It is supported by the bridge in the picture attached, which is pressured assembled against the main plate.
I'm tempted to put it as is in the cleaning machine, but just wonder if there is a different procedure.
Thanks d586e6905be6121b47d54707045d03dd.jpg&key=62c273d500ab9eaade89d0607188a2839b34137b1cc69aa04934c9674aa6cba6a23414dcede0d6189a8e4f87fdc17abd.jpg&key=bb04773c27ee10540533d9bd1578392fe9b9abe36f800b396d0be8adf952e95c
Sent from my SM-G975F using Tapatalk
If you can remove it then do so.  The wheel that is trapped I'm sure has a friction tight wheel underneath and that will need to be oiled.
I dealt with one of these a long time ago and seem to recall the wheel will separate for cleaning.
Just done a search online and this assembly video ...
 ... supports that.
Thanks
The wheel comes out without removing the fixed bridge.
All good now.
Thanks again.
