Glass press machine necessary?
SiZi
Hey, I am restoring my first watch - a Seamaster from the 1970s. I was wondering, do I really need that machine to press fit the glass back in or will my fingers or some other trick do fine for now? Thanks!
Yes, you really need to use a crystal press or it will not seat properly. You MUST use a crystal press.
J
J
Argh, this will set me back a few! Thanks for responding so promptly
Hi The advise given is good , depending on the type of crystal and its setting depends on the tool, some press in with a gasket these are usually flat and hard , some require a bergeon tool and table to compress the sides of the crystal to fit in so be careful. determine what type you have and purchase the appropriate tool.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
