Carriage clock renovation
Alugilac
A carriage clock has come into my possession and, not having the necessary skills myself, I am looking for someone to renovate it. I have had it running and it ticked happily for almost seven days losing a minute a day for the first four days and then steadily more until it stopped. It was about thirteen minutes slow by then. If anyone knows someone who would be willing to take this on please let me know on this thread or if you prefer by pm. It’s not a Drocourt or a Jacot and it’s gilt has suffered over the years but I would like it restored.
I live near Portsmouth so would appreciate someone within15 miles or so to do it. Oh and it’s a striker if that makes a difference.
Go to the B H I site. Type in where you live and it will give you a list of clock repairers around your area. Make sure you pick one that carries out all the work on their premises and give a guarantee. You have not posted any photos, so I don’t know what the platform is like. If there is something broken on the platform, never let them replace it with a new one, it will decrees the value of the clock. It is better to have it repaired.
Thanks for that, I will pop it in and see what his advice is. Just getting it to keep reasonable time would prolly be best. The more I find out about it the more I think it’s probably 1920 ish......still an “old ‘un” but it’s not like it’s by a famous maker or anything.
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
    • At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out. I'm genuinely surprised I've never read about anyone else doing it, to be honest.
