Transplanting a Pinion
I am replacing the hour gear on an old Large Swiss Pocket Watch. The old pinion had 12 leaves and X teeth and the gear I found has 10 leaves and less teeth on the wheel. When I dropped in the gear and then the center hour gear, I turned the crown and everything seems to work and the gears are meshing properly and the minute and hour hands are coordinated (didn’t think that was possible. Now it still feels a little tight in places when I set the time, so I have decided to transplant the pinion to another gear that has the same size and teeth count as the original; plus the original pinion is thicker.16e9331da8e361df3d714f1ecfc9d1f4.jpg735a6a3077676f04028c77411015d183.jpg
So what I am looking for is advice on transplanting the old pinion to the new gear.c48fca3f341ff1c78f637f4795fd1e77.jpg
The pinion I actually used is the one in the movement picture and not the one in the double pinion picture. However the one I used has the 10 leaves. It sort of works. The two pinions I the other pic are the transplant candidates. Just not completely sure how to transplant a pinion.
Sent from my GT-N5110 using Tapatalk
First thing would be to remove the pinions. They are sometimes quite well rivetted, so this may involve turning away some of the rivet or being willing to sacrifice the wheel (it could easily be distorted beyond use in punching the pinion out). Then you need to compare the hole in the wheel you want to use to the diameter on the pinion that will be pressed and rivetted in. If too big it gets tricky, you'll need to sleeve/bush the hole very securely. I would open the hole further, then chamfer both sides, make the bush with an undersized hole, then fit it in. Swage the bush with a convex punch in the hole from both sides, then a flat punch that is larger than the bush. The idea is to deform metal into the two chamfers on the wheel. Finally flatten and clean up. Now open the hole to receive the pinion.
If the hole is too small it's easy, just open it up and press/rivett the pinion in.
This is great advice, thanks
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
