hey - I have  a Timex Expedition wr50m - dropped it and the crown sheared off.
repair shop they wants $38 to fix it (almost as much as the watch costs) - thought I'd give it a try -
any tips for a beginner?
back pops off, but that's as far as my expertise takes me.
thanks you all for your time!
Hi,
No shoftage of advice/ help here, yet a close examination of the patient at Dr office helps, just to be sure.
Post a closeup of the movement,  If neccessary it will be marked where to push/ unscrew and returned back to you.
Regards
don't know the modern Timex very much but, I would first suggest you know that a replacement stem and or crown can be sourced first.
