Can anyone tell me what brand the attached watch is, I thought it was FHF but it isn’t, I’m struggling to find anything. The caliber is 985 but not seen the logo before. I need a setting lever spring for it.
Agree with Nucejoe the logo on the dial side is for sure a standard FHF logo and the style resembles FHF1146.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
