Hello. I am looking to buy an ETA2408 balance complete for a project I’m working on. If anyone has one surplus to requirements that they’d like to swap for beer tokens please pm me. Alternatively, if you know of a supplier in the uk, if be most grateful to hear from you. Kind regards Deggsie.
Well I don't know which reqirements you mean since the 2408 like all other stuff from them comes in different shapes and materials, I got one for a 2804 slightly higher grade, it looks good but might not work for your movement, but in worst case if you don't find one I can send it to you to play around with. Just pop a private message.
Just to update you all. Thanks to HSL kindly sorting out a balance complete for an eta2408, I’ve now brought this attractive gents accurist back to life. Thanks HSL, much appreciated sir!
74b431e76e24459afeb2d9638cfc2e3a.jpg&key=59e2cce36ebe8d3812b1f05b5f691e76c30f28f12e786387e6c598202744a8a0
I'm glad it came to use instead of collecting dust for 10 more years..
Good work with that one, a nice pice of timekeeping.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
