Hi all, I have a 1950s Tudor oyster but the pendant tube thread is worn, is there a method of repairing this or any ideas where I could get a replacement and if I did get a replacement how do you get the old one out. Thanks in advance. Tony
I have replaced a pendant tube on a Citizen watch. The old tube just twisted out using a tap. There are tube removing tools available. Replacing I found also simple as it was just friction fitted just a touch of thread locker just to make sure. If you go the Cousins they sell the tubes and tools.
Thanks just found the cousins tubes so will try and work out the size.
