Hi guys,
First time writing on a blog to find out a few technical issues regarding a Tudor watch that I have recently has repaired. I have previously had it serviced for a full service and overhaul and paid a lto of money on the repair only a few months ago. I have tested the movement on a timegraph machine and the results show that there is a large beat error and low amplitude and a variance in the timing.  If you could please let me know your thoughts?
wow! Well since you said it was recently serviced and giving the watch repairer the benefit of the doubt that he is a pro who knows what he is doing. my guess is watch is magnetized but normally that would yield + seconds with low so i dont know i dont want to bash a fellow watch repairer without due process. if you have a demagnetizer you can demag the balance and the movement separate. if you dont have a "demagger" then you can check it by passing the watch around a compass (do this first either way). if the needle moves off of north then watch is magnetized and any watch repairer can demag a watch within 2 minutes and most likely wont cost much if anything. plus services and overhauls usually have a 1 year warranty.
now if it is not magnetized then either wrong mainspring was installed or he changed a hairspring and just didnt bother to set/vibrate the hairspring in beat. cracked a jewel setting a bridge, many things could have gone wrong. and in that case take it back and demand he fix it.
Edited by saswatch88
Caliber please,   Tudor makes eta movements some beat 28800 bph others higher, this to know and have a baseline to compare readings with.  Also the power level at which these TG readings were produced. Was the piece fully wound?  half full? One hunderdth?  At very low power levels such imperfections are not unexpected  especially if the piece is old.
Regards
Regards
haha i love this man, my response was a little more cut throat lol. but only thing that concerns me though is the beat error nuce. would it be so high or any at all if it was just low power on the train from winding down? and wouldnt these extreme readings be seen within a short time frame before watch finally came to a stop? just spit balling here never really had this issue since i always know to wind my watches when timing, so not sure what to expect under such circumstances.
Presumably both the watch owner and repairman reside in europe, perhaps in Great Britton, so I safely conclude the repairman is licenced and knows in and outs of in beat :lol:.  On the other hand No human being can guarantee a tiny hair didn,t get inside as he screws the back on.
No one is perfect , yet  limited outlook on a given subjects at an instance. If you were to list all possibilties,fault,issues, you wouldn,t leave any room for me to respond.
Thanks to the likes of JJ thompson, Hertz, bose and the rest of great man who showed electrons have spin , EM field exist, and crystals have electrical properties , to give birth to electronics so we can share  ideas across the globe and learn, developements, improvements for mankinds betterment stemming from it, are yet to be seen.
Aren,t we all learning?
Regards
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
