Hello everyone,
I’m trying to reset the second hand to zero but all efforts was unsuccessful, I’ve tried pulling the crown to time setting position and using both push buttons to move the second hand but it didn’t work!
Any help
Thank you all
does every 2 pusher cronograph  use the same method to zero the second hane?   vin
No, other chronograph movements use a different method, usually most of the chronograph movements can be adjusted by pulling the crown to time setting position then keep pressing the start-stop button till you get the second hand to zero position
Some quartz chronograph use the same method. Like Seiko 7A28/38 and ETA quartz chrono .
