Citizen 8960-083997 Crystal Issue
Pip
Hi guys,
This is probably really basic but I am a bit stuck getting the crystal into the above. Well, actually I’m having problems getting it to stay in.
I got this small Arnie like watch in a lot and have been faxing it up for my son as time allows. All done now just about but as I went to reassemble the crystal just seems to float past the gasket and site straight in the shelf in the case. Do I need a new gasket (it was in ok when I got the watch) or is it one that is glued perhaps?
Anyway, some pics. The before pics are a ‘little’ grubby but you’ve all seen worse I’m sure.
Taking the bezel off revealed:
The crystal cane out like this:
The gasket in place is like this:
Now the gasket is still in place:
But the crystal just goes through it with no interference really.
If anyone can point me in the right direction I’d be grateful!
In my experience, this is probably a case of crystal gasket isno longer the correct thickness and the crystal was being held in by years of DNA.
Also if it has a gasket it won't need glueing in just the friction.
Thanks. It had occurred to me that the grit was keeping it in place and I told myself not to be silly! So a new gasket ‘should’ be all it needs you think?
Ok, I need to try and find the right size gasket then. I can measure the height and the OD, is there a standard thickness or a formula related to diameter, or just buy some and see what fits?
I would not try and measure. Just get hold of the correct part from a supplier. Buy once. I tried measuring once and ended up buying 3 times [emoji21]
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
