Nixon Patriot Crown came off.
So the crown on this Nixon Patriot has come off.  I bought this used and knowing it had this issue.  Now I'm trying to figure out if it can be fixed.  The stem isn't attached and i cant tell if the stem can be reattached or if its broken.  Anyone here have any advice or idea of how to go about fixing this?
Is it broken , or has it become unscrewed? either way you will have to remove the back and extract the stem from the movement.if it is broken you are looking at a new crown and stem , If unscrewed you will have to screw it back on snugly.
The stem is likely broken. Mark has a great video on how to fit a new stem. It's posted on YouTube and it takes all the guess work out of it.
www.youtube.com/watch?v=Q_Vt-zJ1ju4
Edited by TexasDon
insert link
Hi  If parts are a bit dodgy you can get stem extenders which screw onto  the original
stem and cut to length,  Assuming its not a two part stem  its a case of taking off the back
and removing the broken bits and a new stem, Whats the watch movement, a picture would
of help in identifying whats required
Ok, thanks guys.  I actually dont have the watch yet.  Its in the mail and these are the photos i have.  I'll check it out further once it get here.  Hopefully i'll be able to use an extender to fix this.  I'm not sure how i would find the correct stem for this but i'll update with more detailed photos once i receive it and get everyones opinions.  Much appreciated.
its a swiss quartz movement.  Is there any guide or way to find out the model number of the stem?  I haven't been able to find anything.  Or if i remove it will i be able to compare it to photos online to find the correct one?  wasn't sure if these can be purchased aftermarket or if they are direct from the manufacturer.  sorry for my ignorance.  thanks for the help.
Once the watch is in your possession, open the case back and the movement number should be stamped or printed directly on the movement. Search for that movement's documentation and you should find the correct part number for a new stem. Personally, I would only consider using a stem extender if a new, full length stem isn't available.
awesome, thanks.  I got some more photos.  it looks like the stem broke off right at the post attached to the crown.  So it could be a problem getting the small broken piece out of there.  only the smallest bit is sticking out.  I think.  The photos arent super high quality. here is the photo that looks like that to me.  i'll figure something out.  I got the watch for 45 and otherwise couldnt have afforded it so i'll give it my best to fix it.  I'm usually pretty good when it comes to these types of things.  Thanks for the knowledge.
Got the watch.  so it does seem that the stem is broken off just at the base of the crown, where there isnt enough of the stem sticking out to unscrew it.  I tried to super glue a nut to it so i could unscrew it but theres just not enough surface area.  contacted nixon to see if the can sell me a replacement crown but havn't heard back yet.  the other option would be to get a small (1mm or so) size tube and put it over the post on the crown and over the stem and secure with liquid weld.  But until i decide, i was able to rotate the stem with needle nose pliers and set the time and the watch is working perfectly.  and the crown is a screw down so it stays on for now.
so they wont send me any parts.  they will only let me send it in to be serviced which im sure is more expensive than i want to spend.  so unless i can find a nixon watch that is broken for parts and has a good matching crown, i'm probably SOL unless i can rig it somehow.
I can see that my movement is a Ronda 6004.B Swiss R9.  Looks like i can get a replacement stem for about $6. I really want to be able to use the original crown because it has the watch logo and exact color match but I dont see how i can do that without finding one off a broken watch or something.  I'm looking into finding a replacement crown for this but I'm also confused on exactly how to order it, which size, threads, etc.  Also having trouble finding the dark gun metal color to match.  If anyone has any tips or advice let me know.  Thanks.IMG_3522.JPG.a1e929181704dc8f2e06d02791cde213.JPG
Find a crown to fit the specs in the attached file:
I would take the crown to a good professional watchmaker and inquire about the possibility of saving the crown. There comes a time to swallow our pride and call in the pros. He may well be able to order a new crown, should that be needed, as he's in the business.
Ronda 6004.B_Stem.pdf
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
