Marvin was (is!) a long-established brand that mainly used bought in movements from the likes of ETA, AS and Felsa for its watches. They did however produce an in-house movement in the mid-1950s called the 580 (which came in a few variants). Can anyone help me, perhaps a guru with a Bestfit Encyclopedia, on whether this 580 was literally a unique design by Marvin or based on a more common movement and thus there are part interchangeability options? I've scoured the internet but found it difficult to come up with any useful information or documents on the 580. Any help would be gratefully received.
Wow - that is brilliant; thank @oldhippy :biggrin:
Your document extensively mentions the ETA 2890 / 2 movements which a quick check on ranfft says came into being in the mid-1970s as a 12.5''' movement. And yet the 580 (and specifically the 580C which I'm most interested in with the calendar mech which I assume is also ETA 2890 / 2 related?) was designed in the mid-1950s ... as well as being a 11.5''' movement.
My reading around the little on the 580 that exists is that it was an in-house design by Marvin but this Bestfit information suggests that ETA pinched this design to turn into the 2890. Sure the 2890 had predecessors of the Eterna 1504 but, that again, was a 1970's movement. Interesting!
I'm going to look into getting a Bestfit Encyclopedia of my own so I can research this more!
Hello,
Adding onto what @oldhippy has posted, here are the Marvin 580 numbers that you can use to match the Bestfit numbers. Its not a word doc, and if you need help with a particular part let me know and I can look up more specific info.
J
905069832_ScreenShot2018-12-24at1_18_32PM.thumb.png.4ed3dc5d250e5dec0dc4b89cc333a843.png
Thank you very much J (@noirrac1j) - that's incredibly helpful.
I've managed so far without a Bestfit Encyclopedia ... and in any case always thought they were weighty vintage tomes with a corresponding weighty price. This thread has prompted me to look closer and find that I can actually get an electronic copy online for relatively little money. It's now on my shopping list!
The main reason for this thread is that sourcing 580C parts has proved difficult so I'm going to see if I can 'BestFit' from other sources. Interesting, for instance, to see that a calendar intermediate wheel comes from a Record 107C!
    • Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.  TZIllustratedGlossary.pdf Watch_tools_tipps.pdf
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
