Hello all with best wishes for a great holiday season and end of year,
My puzzler today involves a record 107c movement in a Kingston watch datofix.
The stem turns the ratchet wheel when winding but the watch runs only when the screw of the ratchet wheel is turned.  Obviously the stem is not winding the spring but the screw is. Anyone know what may be happening here. Just replaced the stem with no difference. The winding does not sound “smooth” but is a little louder than would be expected.
 Thanks
chris
A likely reason is that the square hole in the ratchet wheel has become rounded and is therefore not engaged properly with the barrel arbor. The stem may well result in the turning of the ratchet wheel as expected but  this may not actually be turning the barrel arbor properly. [However because the screw is directly in the arbor then if you use this method then the winding does seem to work]. Also obviously check that the ratchet wheel is properly seated.
Initially I would suggest removing the ratchet wheel screw and gently turning the stem and observe what happens to the arbor and ratchet wheel. [The ratchet wheel should not pop off in the absence of the screw if you are gentle but if in doubt you can always hold the wheel in place with (brass) tweezers].
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
