Hello From Reading
Hello all,
Just joined wanted to say hello to everyone and introduce myself.
I live in Reading Berkshire and am well on the way to being 57 years old.
I am a complete novice having just started taking watches apart in the last week or so but watching the Watch Repair Guy videos on You Tube has whetted my appetite.
I currently own 2 pocket watches, inherited from my grandad,  both not working and both probably only worth just a few pounds each (if that).
Unfortunately I have been unable to identify the manufacturer of either piece but I think they are both Swiss made, one in silver (no hallmark just marked "Fine Silver") the other could be gold plate.
The silver piece has a hairspring problem in that the spring has detached itself from the stud, resulting in a some deformity, plus it seems to have a broken case spring.
The gold coloured one also has a broken spring but it looks like a hairspring so I'm hopeful I can find one in a job lot from e-bay :-)
Well, I'm looking forward to learning all I can and maybe some day I'll be able to get the hairspring sorted out .
Bye for now
Welcome to the forum Ewan, there is a lot of knowledgeable folk here from all aver the world willing to help with all sorts of issues.
It would be interesting to see photos of your watches, I'm sure someone will give you some information on them.
Thanks for posting the quality pictures Ewan. That's a good looking movement in the gold watch going by the screwed in jewel settings. I'm sure some of the pocket watch specialist may shed some light on what you have here. Dare I ask, for pictures of the dials to see what they look like?
Sure guys - I'll be off work in a few hours and I'll take a few more shots then for posting later this evening.
I have a question regarding the hairspring balance wheel on the silver watch as it's smooth - there are no balance screws and the hairspring stud seems to be just a push in fit - is this because its a cheap movement perhaps ?
Anyway, I'll post pictures later showing what I mean.
OK - here's a bit more info and the updated pics as promised.
The silver watch case is about 37mm diameter (outside edge to edge) - the dial is 33mm diameter. The case is marked "Fine Silver" with what looks like a crown mark above the words and the number 101186 stamped on the back case and cuvette (is that what the cover over the movement is called). The movement uses a separate key  - the original is lost. The hands are removed in the picture of the dial and unfortunately the glass dropped out while I was removing the movement from the case.
The gold case is larger with an edge to edge diameter of 50mm - the movement is 42mm diameter. The case is marked "Geneva watch case co"; "case warranty for 10 years " & "TEMERAIRE" with a number of 887116.
Pictures below - would be great if anyone can tell me a little bit about them.
Let me know if you'd like any more pics :)
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
