My quartz watches hand keeps getting stuck and stops ticking, and the crown is very tight and it is hard to set the time. Does anyone know what the problem might be ?
It would be much easier to get an answer if you tell us the brand and model.
And if you post some pics of the watch AND movement.
I suppose you tried to place a new battery but, in case you didn't ... do it.
As @manodeoro says, we'll need some more information and photos to try and help further.
When did this problem start happening; and did it coincide with the watch taking a knock or being immersed in water? [For instance if the watch got bashed then the stem could be slightly bent which might be why it is difficult to set the time. Alternatively if the watch is not waterproof then water ingress could mean that parts are rusting which would explain symptoms]. The more information we have the more likely we can suggest a solution.
