Masters Of Time Video
As for Preziuso's 2,052 diamonds - just bling, as far as I'm concerned. Clever stuff, but not for me.
Both amazing watches, but for me it would be Preziuso's without the diamonds. That said, it's mind blowing to think that each diamond has been set by hand.
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
