Have an old movement with sweep second attachment. An extra third  wheel and an pinion. The problem is that the pinion is wrong. Either it's to many teeth or wrong cut of the teeth. When i put the extra third wheel on the movement it stops. Going to see if i can fix it anyway. But my question is if a wheel or a pinion has more or less teeth in this construction. Would the watch run okay anyway, Only the second hand would go faster. As the extra third wheel on top of the movement turns the second hand pinion.
Edited by rogart63
If it's an extra wheel providing the drive for the seconds then this is known as 'indirect centre seconds' - example diagram below.
If you have the wrong pinion i.e. the green shaded pinion one in the diagram then, yes, this should only effect the seconds hand in some way.
Have you found a picture of your movement type on the web to compare the pinion?
movement type ? If the movement runs without the center second, the problem lies there. If the teeth are correctly sized the gear would be over or under sized depending on the number of teeth. if the gear is of proper diameter and tooth count correct  i think improper shape could cause a jam. inspect the teeth closely under magnification.If you can somehow get a picture of the movement online , do a tooth count.tooth much tension on retainer spring could also cause a problem
Edited by yankeedog
content
the principle at play here is gear reduction. if the second hand turns once per minute  and the hour hand turns once per hour you have a 60:1 ratio. if the minute hand turns once per hour and the hour hand once in twelve , that is a 1:12 ratio. the only way to know for sure is to count the teeth and do the math.rule one problem out the move on to the next variable.
Was just me wonder how it worked. But got the answer i wanted from Watchmaker. The movement is a Doxa 14 with sweep second. I misplaced the sweep second in the wash. Found a pinion on a Eterna 600 that fitted. But think it had more teeth or had a different cut on the teeth. But think i have found the right pinion now.
    • I was thinking it might be nice to see a picture up above or the picture I'm going to paste down below from up above with the escape wheel just setting their. Then it almost looks like the lower jewel is out quite a ways? But maybe it's an optical illusion with the shellac yes the assortment set over time have become something other than what they once were. Like it work with a assortment of Waltham jewels for burnishing in and the last time I tried to find one I discovered there all randomly assorted. Then of course often times the assortments had a tiny quantity of things and the entire container got re-tasked for other things and down the road somebody sells it totally clueless of what they're selling. But in the case of roller jewel's especially after the longer ones of pocket watch size for a single roller then randomly and bottles is definitely good. If you really careful you may bill to place the roller jewel on a flat surface and use calipers although a bench micrometer really is preferred.
    • Have you search for a new winding crown using Tissot case id? You can also find a replacement crown by size / type of the crown you currently have: https://www.cousinsuk.com/category/tissot-crowns-by-size They are dirt cheap.
    • yes the pocketwatch database shows quite a spread in those serial numbers. With the watches typically made in batches and even in a batch from the beginning to the end there be some variations. Then you have approximately a 10 year difference between the two yes some of the stuff will probably not fit especially escapement components as there usually adjusted at the time of manufacturing and of course manufacturing tolerances were improving with time. https://pocketwatchdatabase.com/search/result/elgin/36764469 Grade:    315    Model:    3     Class:    114   Estimated Production Year:    1937  Run Quantity:    4,000     Grade/Model Run:    310 of 329 https://pocketwatchdatabase.com/search/result/elgin/19110954 Grade:    315     Model:    3     Class:    114    Estimated Production Year:    1917   Run Quantity:    2,000     Grade/Model Run:    127 of 329
    • Hope you let the mainspring completely unwind before removing the bridge? Use not only a screwdriver, but a pair of good tweezers with curved ends. This will allow to move various sides of the bridge straight up while keeping it in parallel with the main plate. If you use a screwdriver only and top pivot is stuck, then a bridge is being lifted under angle and then you hear that "horrible click". Usually it takes only one instance to learn such lesson in life 😅
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
