I purchased  a Vintage Marvin on the bay earlier this week. Something up with the winding mechanism or the mainspring. I like the older Marvin watches. I am about to remove the back and noticed the case has a glass crystal and also printed is 10 K Gold Top?
I have never seen the 10K Gold Top. Any thoughts or knowledge?  I will try to post photos. The movement ( just removed the back) is the 310 3 adj 15 jewels. I have been fortunate that all those I have purchased have been in very good shape.
Thank you!
Gary
Interesting Gary, please do post a picture! Apparently your movement is a 310  with 15 jewels... probably adjusted for temperature (x2 = hot and cold) and Isochronism (1) = 3 adj.
See if I can load these images.Not allowing me to upload...Error, message that I don't have permissions.
Edited by Gary
Hi Gary, I don't know much about marvins but this one looks really good. You said it has some problems, what is exactly what it won't do?
On the other subject, maybe some other member can tell us more.
Hi Gary,
Thats a nice find you have Gary, especially with the 3 adj. I don't go for square watches, but the movement looks good. This is a tough one for me because I don't know Marvin watches at al--glass crystal and no shock on the balance pivot says it might be from the 30's? The gold top you oriobably know means that it has a layer of gold mechanically rolled over the case and bracelet as opposed to electroplated. I believe it is also superior to gold filled. Pictures of dissasembly?
JC
Edited by noirrac1j
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
