So I'm putting together parts for my second watch build. I've got a 2824 case in the mail. It would make sense for this one to be quartz because it won't see much wrist time.
So if I purchase a ISA 1198 what problems am I looking at? I know the second hand is a different size. Will the crown fit? Is there any issue I'll run into if I decide to go this way?
isn't the stemheight totally different? Do you have only the case of also the dail?
Manufacturer: ISA
Size (Ligne): 11-1/2 Round
Thickness: 3.25mm
Hands: 90/150/20
Width: 25.60mm
Watch Battery: 395
Jewels: 1
Watch Stem:
ISA1198-STEM10, Tap 10; or ISA1198-STEM08, Tap 8
ETA 2824-2
Features
automatic
sweep second
date: quickset
option: hack feature
Data
11.5''', Dm= 25.6mm, Do= 26.0mm
H= 4.6mm (H= 4.7mm with ball bearing)
F= 1.2mm
T= 1.8mm
17/21/25 jewels
f = 28800 A/h
power reserve 40h
Balance staff ETA 2801
Stem W3738
Mainspring / battery
1.25 x 11.0 x 0.125mm
Hands
1.50 x 0.90 x 0.25mm
You can check the stem heights on Ranfft. I've heard of people sub the 2836 with an 1198.
Awesome website. I've just got to figure out how to navigate it. I appreciate you telling me about the website. It seems to be a treasure trove of info.
The figure you are interested in is "T" which is the stem height. Looks like 1.8mm for the 2824. You'd generally want to get this figure to be a fairly close match for the replacement.
Thw 1198 may come in differnt versions of stem height depending on if it has a date complication, etc. Check the datasheets.
Thanks Rodabod! My ability to access what I need just jumped exponentially. Im going to download the complete website on to my laptop later so if the website goes down I'll have a backup to use.
20 hours ago, Rattlerviper said:
1198-103 is 3.7mm high while the 2824 is 4.6 mm high. Does that mean I would need to create a spacer for the back of the movement?
It depends on how the movement is mounted in the particular case.
