Hi all.
I need a diagram of the keyless work for RL1239.
Ranfft prodives pictures of this movement. I have checked the net for diagram of keyless works to no avail,
Perhaps due to my limited access to the net.
Just though other source may show the keyless, or someone may know.
Much appreciate advice.
Regards joe
I have done work on a similar movement. It has no auto-rotor but the same basics. Ronda 1217-21 17 jewels. These are pre cleaning pics... Hope this helps.
Edited by noirrac1j
He!lo Sir,
I was so embarresed posting half composed question accidently, I forgot editting my full composed question.
I don,t know where parts of day date works go.
The picutres I have taken to post for reference are low quality. So until I take better picture, a ready diagram picture seemed the only choice.
Though the movement  runs real good, I might as well clean and service it. Clean so details can be seen in picture.
There norriac just posted better quality pictures
Much appreciate your help
Regards joe
How assemble the day date works, where dose each part go?
@oldhippy found a nice pic. Follow that for reference and try installing the parts you have numbered. Out the date wheel, then the parts in 5, then 4. Use clear wrap an be careful you don't lose that spring, then install 3,2, and 1.
J
2 hours ago, oldhippy said:
This should help you.
Thank you Sir. This perfectly clear, Much appreciate your help. Regards joe.
J
Yes it is just what I hoped to find, I plan to clean the movement now that I am  at it, will show the serviced watch. Thanks for taking the time to he!p. Regards joe.
    • I am sure you agree that,    " physical reality is actually made up of structured information "  which defines the states energy may  realize in prescribed  states.      Universe is committing suicide then most of its functions stops, but what we know as  gravitation remains, thus ( as he concludes)  gravitation proves of no essence  for actualization  previous functions universe used to work according to.   No doubt mathamtic systems man has deviced  is basic and not neccessarilty correct . But if universe is informational,  its also computational.   Then we have something thats has no essence and computation systems indicates it as virtual.
    • Oh that is lovely, thank you. I also just cracked the crystal and lost one of the shock absorbers, so its gone in the separate baggy of 'maybe-one-day' 😄 I did learn the valuable lesson of not disassembling the shock absorbers. My next one is a Zaria 1509B. I think this one I'll take a bit more time with cause I'll need to source a couple of bits. It's also scary teeny.
    • More data on the oscillation tests: Vertical: 15-20 seconds…Abysmal Dial up: 1 min 15-30 seconds Any thoughts @nevenbekriev @JohnR725? My next thought is to oil the balance jewels to see if that helps. It’s certainly one major thing left that I haven’t done.
    • Hi. Once the pins have been withdrawn the brace let comes apart, never had a problem with these.
    • Hello and welcome to the forum added the racketa 2603 sheet incase you don’t have it. 4328_Raketa 2603.pdf
