Omega 552 amplitude problems
Thanks Andy, The bracelet is sized very small, around a 14cm wrist. Were would one try to source original links, I guess they wouldn't be cheap if found. The bracelet end links have 4406 B-E stamped on them, is this the Seiko Bracelet code ?? CJ
If it's 16mm at the clasp then you need to order a 16mm extender. How short is it and have you tried looking for extra links.
You won't get any feedback offering the plate to the screw by lathe, at either the pmate or headstock where the screw is mounted. I'd go for offering the screw to the plate, by hand in a thin pin vice, you'll feel much more of the process. How good is the cutter ? -
Hi, Can someone advise me how you size and order the correct extender, the strap width is 16mm wide where it attaches to the OEM clasp/buckle Seiko 7S26-0060 https://www.cousinsuk.com/product/extenders-for-3-fold-clasp-covers Thanks CJ
Extraordinarily generous of you, and I thank you regardless. 🙏
