Timex watch
Roy
Please can any body help I am searching for a back to this watch which has been lost, I have been in touch with Timex via email explaining everything including a lost back, and received a reply " thank you for your email to help you please can you give the details on the back of the watch ie: serial No etc" I don't know who Timex employs or where they get them, I sent them another email with the same info and stressed about the back was missing but Never received any reply what so ever. Please has anybody out there who can give me any information which could help me try and get a back for the watch. Roy.
okay Roy, let first discuss the request you made to Timex.  Did you give them an idea of when the watch was made?  reason is like most any manufactures, maintaining an inventory of parts is costly. So the time frame they keep parts is limited.  Now take into account your watch is from 1971 - 1973, would it be practical for them to have parts for 40+ years?
Now back to the missing back, and BTW you are missing the rotating bezel was well.  I'm about 99.99% sure I have the back.
Thank you clockboy for your for your reply. My measurement to the inside is 30.93mm and to the lip where it will clips in is 32.16mm . Thank you Jersey Mo for your reply, I can understand the Timex remark you say but having told them the back was missing in three emails all they needed to tell me was "Sorry,but we are unable to answer your request due to the age of the watch" The rotating bezel is the one shown with the two holes.  everything works on the watch and keeps good time, just the back is missing. Thanks again.
3 hours ago, Roy said:
Thank you Jersey Mo what does the rotating bezel do and look like and where would it go. I just thought that the watch was complete as it runs perfect.  Roy.
I am referring to the black plastic ring around the dial side of the case.  These are called elapsed time rings and can be used to mark when a certain amount of time within one hour has past from the current time.
Since your case is that of a European model "note the 25 Meters", it may not have the feature of the time ring.  The ring fits to the case by way of lip. So you should see an indent or cutout that goes all the way around the area.
Here are two cases, one that requires a ring and one that does not.
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
