Hi the back face of this gucci watch fell off (no idea how that happened). I sent the watch to Gucci and they charged me an obscene amount of money (basically almost the price of the watch) to fix it. I would love to hear some alternate solutions for a fix. Is there a place where i can get the exact dimensions of the back? Where can i get a spare for this? Is it possible to machine a replacement part (or 3d print it). THanks to all in advance
Arv
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
