Help with the old clock
I set apart this old clock, cleaned it, and now I want to oil it and put it back. Using the photos I made during the disassembly, I reassembled it just to the end. Now I have problem with these two giant springs on the right side. Either they wont get in place, or they just jump out suddenly. Any idea how to put all this back? Thanks.
https://imgur.com/a/KdUUxBa
If the movement is back together and screwed/pinned. You need to make sure the spring is hooked on the arbor then wind it up, when it is nearly fully wound you need to feed the end of the spring over the pillar, which will hold it in place. Repeat with the other. So the spring catches the arbor you might need to pull on the spring part way in so as to take up the slack and the end is tight on the arbor.
Let me know how you are getting on.
The problem is actually how to wind up the springs, in order to put them in the cage. Once they are wind up, it is easy to hook them on arbors (in this case they are the upper supports of the whole clock cage). But they always jump out, and I also have other wheels to put in (at least four of them). I already decided to put the balance wheel last.
At the beginning of the process, the springs are unwound and take a lot of space. It is hard for me to wind them enough so they can be placed in the cage (since the springs are attached to the upper bridge so to say). So, I need to wind them enough to put them both in the cage, and then hooks the end on the arbors. Then they are under tension and that is it. However, once I try to wind the spring, and put them on top of the movement, they jump out.
  • 4 months later...
Hello again,
I have finally time to get back to this old clock (Viktoria 7 jewels). Still, I have no idea where to start and I expected it would be a lot easier (I mainly worked on watches and this thing is huge). I did found the photos I took during the disassembly but they are not of much help (here: https://imgur.com/a/subHhf1)
Did anybody recall any similar clock mechanism whose drawings I could use to put this clock back?
The most difficult part are still the huge springs (especially two of them which are kinda connected). I didn't find a way to put them together them in cage (they always fly get out somehow). Other parts are mostly in good shape and with a proper lubrication should be fine.
Edited by bojan1990
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
