Thank you, I will...
Indeed the base movement is a 2892-a2 so there's just the added GMT complication under the dial. I haven't done a video bit I have worked on them and they are not too complicated. It's a 2893-2 movement - perhaps cousins has a data sheet detailing the differences and lubrication points.
Sent from my SM-G950F using Tapatalk
However, the first one I bought quit working about an hour after I started wearing it. So, I took it back and they replaced it with a new one but it had an issue with the GMT hand; it moved 4 hours instead of one on the 24 hour dial. So it was sent back and they replaced the movement. Now it works perfectly and they were embarrassed to the point that they threw in a travel case and a winder to boot.
I'm wearing it now...
