Hi gentlemen,
I have a cheap watch with a chinese movement in it, seems to be 2813, and that watch has a "weird" problem.
Sometimes the hour hand and minute hand stop for a moment while the second hand keeps working ... then after some minutes th hour hand and minute hand work again.
I have read on the web that this problem could be caused by a stem which is too long.
So I tried to wind the watch and let it on my desk with the crown in winding position but unscrewed (its a screw-down crown) and the watch keeps the time really good.
The I tried again with the crwon fully screwed and the watch stops and works and stops and works, etc ... but the second hand keeps working.
So my questions are :
1 - does anybody on the forum have had the same problem ?
2 - should I file the stem a little shorter ?
Cheers
If a watch stops and starts its normally a sign that its dirt. It doesn’t have to be dirty, just a little speck moving around in the movement will cause this. When the watch stops are the hands over each other, if so it could be the hands. I do not know where you found out about the stem. That is a new one on me. I bet it is dirt.
Thank you oldhippy ... I'll try to disassemble it to see if there dirt anywhere
