I was given two old watches to fix yesterday. An old Everite and a Longines. They have been in a drawer for many  years. I stripped the Everite,  and well serviced it but it does not run well. The Beat error is 600 micro seconds (0.6 mS) and the balance amplitude varies between 140 and 190 deg. The HS is fine. The lever flicks to the banking and the Draw seems to be OK. It is keeping time to about +2 mins/day face up and a smaller amount face down,  The best I can achieve.  It does not look very good on the timegrapher. Is this a case of general Bal/Esc wear. The end stones look OK. Under the microscope I can see pallet jewel  witness on the teeth of the ESC wheel.  It was purchased in the thirties and used for many years. I have boxed it up. Perhaps someone will comment.
Did you check the impulse jewel to see if it was chipped or loose? What type of oil did you use on the ecsapement. You know pallet pivots should not be oiled as it can and will cause drag.
Thank you for your help Oldhippy. Yes, the impulse jewel is firm. I used a tiny amount of 9010 oil on the escapement but not on the impulse jewel. I did however use a touch on the pallet pivots !!!! I will remove this today.  I do not feel safe without the tiniest touch of oil on most bearing services, a habit that I must get out of in some areas.  I can see where you are coming from with regard to the pallet pivots not being oiled, oil could be the cause of a weaker impulse to the balance,  I will let you know how I get on in due course. Many thanks for your constructive and expert help to an old Jobber !!. Best regards, Mike.
Hi oldhippy, I have just finished the Everite watch and your comments about oiling the pallet pivots were Spot On!. I cleaned them with Acetone, dried and then re-assembled the balance. The balance now has a steady 220 deg. Amplitude.  I have timed it to +30 Secs per day. It is much better now. Thank you so much for your correct diagnosis and perhaps 9010 is a little stickier than I thought. I have learnt something from your years of experience and am most grateful to you. Thinking about it there would no real need to oil the pallet bearings as the rotational moment is so small,  I realise this now that  you pointed it out.  Thanking you again,  Best regards, the old Jobber  Mike.
spot on !.
Thinking about it there would no real need to oil the pallet bearings as the rotational moment is so small. That is correct. Glad to be of  help.
Thank you again. I could hardly believe the oil on the pallet bearings could have that much effect. I will not oil them again. Mike.
PS. I always maintained  that in any kind of engineering,  if there is a problem that is elusive the smart guy is the one that diagnoses it. The  fix being the easy part as a rule. thanks, Mike.
  • 1 year later...
Yes it is hard to believe the retarding effect of oil on pallet pivots. Even worse is: if the watch( some movements, especially pin pallet)  isn,t worn for couple of months, oil can freeze the pivots from functioning.
    • I am aware of one eBay seller who does cases for some American pocket watch sizes and also sells a case tube & sleeve assembly to work with American negative set keyless https://ebay.us/m/qa0ubk Also I have seen this seller many times but have never been clear on how they handle stems and crowns. https://ebay.us/m/4mhfEr I general though I don't think there are a lot of these cases out there, just a few sellers custom making them or adapting AliExpress cases somehow.
    • What type of glue you figure it was. I wonder if acetone dissolves super glue.
    • What's the movements so we know what size cases you're looking for and what are the setting requirements.
    • As I am getting close, I would like to know the total thickness of the bezel (top to bottom).  I am working on two solutions--one is thinner than the other.  The crystal sits pretty proud relative to the bezel, and seems consistent with the pictures I have seen.  But, actual measurements would be nice.
    • A little bit of superglue and you'll be good to go Although maybe if you had a laser welder you can weld the spring back together. Typically I've only seen it on blued steel Springs and on one occasion a modern spring? The modern watch was a Rolex watch that came and that was literally filled with rust including the barrel was filled with rust in the spring was in a whole bunch of little pieces. I have to wonder if that was an aftermarket mainspring . Then I'm attaching a PDF the Elgin watch company as you can see instigated a study in the 30s find out why mainsprings were breaking. I do though wonder if perhaps there may be a flaw in their study? One other things I wonder about is the metallurgy of the early steel Springs versus the later generation of blued steel Springs whether the metallurgy as part of the problem but in a case they did a study and have attaching a PDF. Because of the study any time I do anything with the blued steel spring when I actually cannot get something that's not blued. Once the spring is cleaned I'm very careful to not to touch the spring with my fingers because I don't want to have a problem with the chemicals on your fingers causing rust and I very carefully get lubrication back on the spring as fast as possible just to avoid these unpleasant situations. Then yes it is interesting one minute you of functional spring and the next minute you have lots of little pieces of spring. For my own personal Elgin pocket watch I put a steel spring and in this happened I'm also guessing that when one layer breaks it sends a cascading shockwave through the spring and that's why it breaks all the way across because after all there is a lot of energy in the spring when it breaks. Oh and my theory on the metallurgy is based on things have improved and for the most part I don't think I've seen a shattered spring in quite some time.   Elgin_Mainsprings.PDF
