What is this levers purpose
clockboy
Working on another Westminster clock and hit another issue. I guess I have got the sequence wrong because the chiming cam does not stop until this lever hits the high spot on the hour segment. I can not fathom what the purpose of this lever is. It has a flag shape on the inside and this hits a pin on a wheel and so stops the chiming wheel. This arm was badly bent & I have straightened it and also the pin is also bent and it looks like the flag part is badly worn. Any ideas what its function is.5aed9bad17e3c_Whatisthislever.thumb.jpg.219aca0db1a7451a61e5e5f5037f635f.jpg5aed9bbacd756_bentlever.thumb.jpg.219e8e3f1ebeef80ec50d8ddfa4ee4f0.jpg5aed9bc5c40f0_leverwedge.thumb.jpg.422eeb2b368e6e2ab4664365101743db.jpg
That part is not worn. Providing it is smooth it will be ok. The lever with red arrow should lift and stop the wheel with pin on the worning. When it drops the lever in the cam wheel will rise and travel until it drops in the next space, in turn the lever with red arrow should also drop ready for the next sequence. Those two steel bent pins need to be the other way around, they could drop out, the thick parts should always be at the top.
Thanks oldhippy because of a family issue I will not be able to re-visit this until Monday.
I have had the movement apart several times & I did have it all working correctly apart from when it was on the hour. As the chime wheel/cam turned it was OK until the levers pin raises on the high part of the hour wheel/cam.Then the top part of the flag part rests the pin on the wheel. This then stops the chime wheel turning. Is this correct or should the pin not rest the wheel at this moment. The reason I am thinking this is the arm of this lever was bent downwards & I guess a previous  repairer had come to the same conclusion.
If the wheels and levers are set correctly you should first have the warning then release for the clock to chime then stop. The wheels and levers should then be in the same place apart from the cam wheel, which would have moved to the next position for the next chime.
If it is tripping, then I would say this lever is at fault. The part with black arrow should be straight so the steel pin sits straight into the cam and not at an angle. The red arrow part should be straight to the black part. The part with green arrow should be smooth so the pin slips away easy. Some are set at an angle, but I do not think so with this movement.
Thanks. I am pretty sure everything at one stage was correct ie levers & wheels in the correct position. The only fault is when the lever rides over the raised section of the chime cam. It locks the warning wheel pin. However I have come to the same conclusion that this lever is the fault. Where you have the green arrow is rough almost as though someone has reduced it with a rough file, it is also in a wedge shape.  The lever was badly bent and the pin does not sit straight. I will (hopefully) have another look tomorrow.
Thanks again for you help much appreciated.
Thanks. Found out today that the clock has not run for approx 5 years. Customer just hoping for it to run again. The clock part works great just the chimes to sort. Maybe tomorrow I will be able to sort.
I think the fault has been eliminated. The lever that Oldhippy suspected was the fault. It had two faults the, first was the flag was catching the warning pin because it had a very rough surface, secondly the lever was bent outwards so it was catching the chiming cam (see pic). I have had it on test and it chiming in the correct sequence for the 1/4, 1/2, 3/4 & hour. Just need to re-aasemble when time (family issue)
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
