Pin Pallet Beat
What do you use as pivot drills @nevenbekriev?
By HectorLooi · Posted
If you use your brass tweezers to hold the escape wheel by the pinion, can you turn the wheel with your fingers? -
By RichardHarris123 · Posted
Of a pivot is broken and they are not engaging. -
That means that the escape wheel's abor is loose. The wheel remains stationary while the pinion is spinning.
