Technique for threaded barrel arbor?
I'm working on an early 1900's Vacheron 12''' ligne movement. I took my time with servicing it and everything went well. As I often do with my own oldsters, I left the mainspring alone. If it's just going to sit in a cabinet or movement holder, I'm not super concerned about perfectly strong running. However, this little V&C ran great, but only for a short time. So I ended up pulling the barrel to look at the mainspring. It looked OK, as much as one can tell when it's still in the barrel, but when I pulled it out of the barrel, I saw it was very badly "set". After a few bad experiences, I'm a bit loathe to mess with Swiss barrels that have the threaded arbor. But on this one I have to.
Does anyone have any tips for holding the catch side inside the barrel while one turns the arbor from the deeper square side? There are two holes on opposite sides of the center that look like there must be a special Swiss arbor tool, like a small snap-ring plier, to work with them. I have read that one can use brass lined pliers to hold, but I don't have those. It's a nice Vacheron, so I'm really trying to leave as few marks as I can on parts. I've already put a few scratches inside the barrel while trying to unscrew the arbor.
If I don't have success getting the arbor to separate, perhaps I can pop the mainspring in with the arbor already in place? It seems possible, but perhaps a bit tricky. Any help is appreciated. Cheers.
Edited by MrRoundel
spelling
6 hours ago, oldhippy said:
You could use tweezers grind them down so they just fit in the holes, that way they would not slip out and mark the barrel.
Thanks, oldhippy. I started to do that with my best tweezers, but thought better of it. That's a good idea to use one of my older, or at least cheaper, sets of tweezers in the way you suggest. I'll give it a shot. Cheers.
Well, gave it a shot with the tweezers. There seems to be too much flex in the tweezers, given how tight it is. I'm using a multi-sized bench key to hold onto the square end (non-stopworks side). It holds, but does seem a touch too big. I guess I'll have to get the right sized key and give it another shot. I'll keep trying, no matter what. Thanks again.
Well, it was really on othere. I ended up looking in my pliers drawer, and found a vise with a sliding tightener on it. It has bailed me out before. I was able to grab the sides, away from the spring catch, tighten with sliding loop, squeeze a bit tighter by hand, while I loosened with the multi-sized bench-key. It got it, but barely. Now to find the right mainspring. Speaking of that, it measures around 1.68mm wide and .12mm thick. The only springs I see are widths of 1.65mm and 1.70mm, nothing in between. It does look like there should be just enough room for the 1.70mm, but perhaps a 1.65mm would be the safer play. Hmm...
    • Many would disagree: https://www.rohm.com/products/faq-search/faqId/234 https://uk.farnell.com/c/semiconductors-discretes/transistors/bipolar-transistors/pre-biased-digital-bipolar-transistors https://uk.rs-online.com/web/p/bipolar-transistors/8232832P?gb=s https://uk.rs-online.com/web/p/bipolar-transistors/0580240?gb=s (RS don't have a specific category, but over 1000 "digital transistor" items).
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
