I'm new to this forum and fairly new to watch repairing (following BHI distance learning course) so I hope this question is in the correct place.
I'm wanting to replace a broken mainspring in a pocket watch and have identified the GR6413 as the correct size spring.
This has a "normal bridle", but I'm not familiar with this term.
Can anyone advise me of the hookings for this spring? Is "Normal Bridle" the term that GR use for a resilient hook?
Does centre of the spring have a eye cut for a snailed arbor?
Thanks for the replies, I've added a couple of pictures.  This is the hook:
And this is the barrel (yet to be cleaned)
The centre of the spring is a standard eye which goes onto a sailed arbor.
Does the GR6413 have these bookings?
Thanks
Mark
Thanks
Mark
A normal non-automatic  mainspring will do fine. GR6413 will work. That has a normal bridle. Just pop it in and it will hook into the cut out when you wind it up.
Edited by rogart63
