I successfully (mostly) finished cleaning, oiling and reassembling my first mechanical watch yesterday. I bought a beat up old Caravelle and three movements worth of spare parts. Unfortunately, I dropped the one good balance out of four and mangled the hairspring, so I had to use a backup. The watch sets and runs, but doesn't run well. Also, I switched the dial from the original to one I liked better without thinking to check that it would fit the case - it didn't. But I got it all back together, so I'm considering this a victory.
Before:
During:
After:
If you're observant, you'll notice that the watch changed from 7 to 17 jewels somewhere in the process. You'll also notice that I had a little trouble with the concept of reverse threaded screws. :growl:
these are all things you have to learn...usually the hard way like I did! If you are like me and never had formal training, your mistakes are burned into your brain and you never forget what you did wrong to cause them! I'm not saying they will not happen again, but usually not for the same reason....
Hang in there! it's so gratifiing when you get through an overhaul and the watch is running beautifully!
FYI-Also, you'll notice the screws with the reverse threads have 3 lines on the screw heads, This is usually a dead giveaway that they are infact reverse threads...
Watches are a whole different world,  most other things are made with parts you can see and pick up with your fingers,  not watches.  Well done,  your next one should go better.
Well done - I'm on the same track but I've lost a **BLEEP** screw and I don't have any spares.
The reverse thread screw on the crown wheel got me too.
That's where Marks's videos come in handy - this reverse thread is mentioned in them!
Yes, yes. But where's the fun in following the instructions? :)
Thanks for all the positive comments. I really love this forum. :D
DJW, you're spot on about making mistakes. Each one taught me something. It took me forever to figure out why the stem couldn't be pulled to the setting mode and why the train was locked up. Turns out when you use a ratchet wheel screw on the crown wheel, it doesn't work so well. I'll forever remember the three slotted screw thing too. Most of the setbacks were very enjoyable because I felt I was gaining experience.
Thanks Bob. I ended mashed the different movement parts together and ended up using the trail wheel bridge from a 17 jewel version. I'm not sure if I've got all 17, but the bridge says 17 jewels.
I've already got my next victim, a vintage Lucerne that is currently running slow. I'm looking forward to having the time to tear it apart and apply whatever I've learned from the first watch to it. When I get more confident, I'm going to have a go at a Stowa I bought 5 years ago and have been dying to get fixed.
I've got a used L&R PC3 ultrasonic cleaner. I used Zenith Hi-Tech cleaning solution and Zenith Hi-Solv for the rinse. I couldn't find much info on the Zenith products as opposed to the L&R solutions, but I chose the Zenith because they are advertised as low odor. So far I'm very happy with it.
I'm a little ashamed to say that I didn't read the warnings on the container, but I assume there is some risk of ignition, especially with the rinse, since it evaporates very quickly. The smell was not bad at all for the cleaner and rinse, but I also bought some hairspring cleaner from Zenith and that stuff smells pretty potent.
Hi Don,
Re the 7 to 17 jewels things...?
Are you going by the sloppy stamping on the train bridge? I think that its a legit 17 jewels as the 'seventeen' would have been there from the beginning... just a bit of carelessness.
Anil
Hi Anil,
I had parts from three movements. The one I started with was a 7 jewel version. I ended up using the main plate and train wheel bridge from one of the others that was a 17 jewel version. In the "before" picture, the train wheel bridge bearings are not jeweled.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
