A Nice 9Ct Gold Longines From 1964
WillFly
I'm slowly adding to my collection of gold watches. (thinks... am I getting blingier as I get older...?) and made an offer on a nice, simple Longines this morning. Which was accepted. I do like Longines movements, which are generally beautifully engineered. It's in a Baumes-made 9ct gold case, hallmarked for London, 1964. The pic of the movement's a little lacking in contrasts - I'll post some better ones when it comes. Also a few marks on the sub-seconds dial, but I'm not particularly worried - I like to keep watches as they are, if possible, with all their history.
Edited by WillFly
That's potentially a really nice watch. Do you intend having the dial refinished?
It's a possibility. I'll look at it in the flesh when it gets here and see what it's like in general. I'd prefer the dial to remain as original as possible, but - if need be - I'll get D.R. Bill to do it up, which will be in the region of £70 or so. (He's just quoted me £83 for a chrono dial refinish, and the chrono is far tattier than the Longines).
Edited by WillFly
Thats a very nice top quality watch Will,  a few pounds spent on the dial and it will look like new.  It would be interesting to know how many ticks it's ticked since 1964,  got to be in the millions.
Just out of interest but if you want the dial restored do you have to remove it yourself or just post them the watch and they remove it?
The watch arrived this morning, in good nick and starting up on the first wind. I'll time it over the next 24 hours and see how it goes. The casing is in excellent condition, as is the movement, which is a Cal. 19.4. Interestingly, the watch movement dimension, according to Ranfft, is 8.75 lignes - which is 19.4mm. So - did Longines allocate calibre numbers by the dimensions of the movement? A quick check on other Longines movements in Ranfft tells me: No! Probably pure coincidence.
Anyway, some pics of mine. Looking at the dial in the flesh leads me to the conclusion that, at some stage, I will get the dial cleaned up.
Edited by WillFly
Better that the first pictures! It is a very, very nice watch...at the risk of repeating myself! Congratulations Will on an excellent new jewel for your collection!
As a side note, did you know that Longines was the only other watch that flew to the moon with the Omegas and actually helped the crew? There is a story behind that I have to look up, something about failing computers and emergency landings similar to the Omega story. The watch in question was not officially sanctioned by NASA but one of the crew took it with him and actually was indispensable at the time, performing flawlessly under those conditions.
Edited by bobm12
No - I'd never heard that story - I'd love to know more...
I read it once on line, and it looked legit. Now all I can find is how great Omega is and a long "course" on Swiss quality by Swatch! Weird because it was only this one incident I read about...not talking about the Rolex GMT Master that landed the Apollo-whatever-number nor the Bulova Accutrons and stopwatches officially adopted for timing tasks by NASA but something related to a module landing on the sea somewhere: small but important. The astronaut carried it just for testing or out of habit and it came through instead of the intended equipment.
Now, there is also a Whittnauer that filled in for an Omega when the later popped its crystal due to the pressure... and found references of other brands at different times, including the Seiko 6139 on the Skylab but complete silence for Longines which doesn't seem right. Information suppressed? Don't get me wrong, I love Omegas but fair is fair.
In any case, Longines have a long history in sporting events and other significant activities and was considered for testing by NASA for space flights. There were a reduced few for this testing. According to the web, only Omegas passed but that doesn't retract in quality and/or prestige as we all know. I believe most movements for space purpose were -- or similar to - the Valjoux 7734.
Edited by bobm12
  • 3 years later...
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
