So I was at the local sunday market today, and happened upon a weird little digital watch. I normally avoid them, but this one was a pulsar and it caught my eye.
It was missing the strap - the seller was a big old man in his 60's selling knick knacks like beer glasses. He was asking $5 - I tried bargaining down to $4 but no cigar.
I scored the digital watch and a Russian 9micron Gold plated Zarya with 16 jewels in running order (ladies watch).
In Australia it is quite hard to find anything other than ladies watches because there are hundreds of blokes going around to all the thrift shops and buying up the gents watches. As most men over 40 here are divorced - they have nobody to buy ladies watches for and hence normally I have my pick.
This was a lucky score to find a unisex/mens watch - I knew from straight away that it was something interesting - It had a large screen with many buttons, I initially thought it had a HR monitor or excercise function. From research it cost around $200 US in 1999 and was quite a trendy watch at the time. It is powered by a Seiko module with a pulsar assembly in "China".
I got it home and started having a good look:
According to another watch blog, it has the following features:
Other modes are:
- address book
- memo/messages
- chronograph
- timer
- alarm
The full model number is: W440-4000
Beautiful working module
Very grubby - but it is 100% complete minus the strap.
It is a plastic/resin body with a base metal brass bezel that is chrome plated.
It has resin/abs pushbuttons that are fully spring and water sealed.
It has a stainless steel case back with a waterproof seal.
I plan to replate the chrome.
Spotless back - apart from minor marks.
These watches were designed to be serviceable. Not like modern rubbish which is sealed for life. This beauty was able to be stripped down to the bare nuts and circlips.
Starting to ease the buttons out.
Mint original glass- will gently polish it thats it. (Mineral glass)
Spring bars for the assembly.
A little trick I use to remove circlips.
fFGZoFi.jpgA photo of the module
Nice and clean
AN old article about the watch from Popular Mechanics;
Edited by AlexeiJ1
SO I have stripped it down, I will chrome the bezel. Get a new battery - refit all the seals and buy a strap.
Updates will be in 2-3 weeks :)
Oh yeah and will have to respray the case silver
That looks very cool, especially for a fiver! Looking forward to seeing the completed piece.
  • 2 years later...
Hi! I was replacing the battery in this Pulsar X440 SAM spoon watch, and a piece came out that I can NOT figure out where to put back!! Rookie mistake I know, but can anyone tell me where it goes?? Pics attached.......
What piece?
  • 3 months later...
Hi.
Alexei I am doing just the same on a black spoon web that I purchased in Japan in 2002 i think.
Did you find a decent strap to fit the watch? I was going to find a nice g-shock 22 mm strap and cut it back to fit the pins if need be? The original strap had a wonderful closing clip like a divers watch.
Anyway I would be really interested to see how you rebuilt this great little watch that can do so much. I have all the original instructions! In Japanese.... ??? It is quite detailed as you can type messages into it etc.
Thanks.
Simon
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
