Hi all,
I'm looking to take apart a Seiko watch for cleaning, but can't figure out how the winder comes out! If anyone could help I would greatly appreciate it. I've done a few watches, but this ones got me stumped! Thanks in advance for any help.
Andrew
seiko 1no1 or 1n00 something, right?
There is a very tiny lever on this (to the left of the stem if looking at it with the stem and crown pointing away from you) that for some reason is virtually impossible to operate unless you loosen the screw near the steam a couple of turns even then its tricky. Add to that you have a rusty stem and you might be in for a challenging time.
If it's just a pragmatic thing for you id say better to replace it than clean it, if fun is a factor knock yourself out but this is a tricky one so expect problems. that being said, good luck. :biggrin:
Edited by Ishima
Thanks for the replies, yes looking at this closer image you're right about the model number. I just about see a lever ( I think!). That's gonna test my eyes and steadiness of hand for sure! I should say that its the inside of the glass that needs cleaning and the front bezel isn't quite as scabby! :-)
If you look into the hole in the movement just to the right of the p in time Corp, you will see a brass object with a tiny hole in it. If you pull the crown in and out, you will see that appear and disappear. When it is visible, you are to push on the part with the tiny hole and pull the stem right out. It is on kind of a seesaw lever that when pushed down on one end, the other end lifts up and releases its pressure on the stem/keyworks. When you put the stem back in, make sure not to accidentally push that lever back into the disappearing setting because the keyworks will get out of position. It isn’t much of a problem with a small Quartz watch but can be a big headache with a good mechanical movement, because then you have to remove the hands and dial to get to the keyworks to put everything back in place.
Sent from my iPad using Tapatalk Pro
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
