Does it perhaps have a screw-down crown? If so, you must first unscrew the crown, going counter-clockwise, pull out to the furthest setting, then set as usual. After setting, push crown back in as you tighten, turning clockwise. If that, or conventional setting w/o unscrewing crown doesn't work, I don't know. Good luck.
Hi.
Thanks for the info. But the problem is still present, I can't set the minutes. There is no push center on the winder but if I push it tight to the case it just stops the minute hand. Could this be a wrong winder??
Regards.
If you read step number three in the link above pushing in the crown stops the secondhand exactly what you're describing.. This is the Lau you to synchronize the second hand with a time standard. Then if you rapidly push in and out the secondhand should jump forward each time you push in and out. Then step four explains how to get the watch to run really fast so the minute hand who go to wherever you wanted to go try not to go past because you can't go backwards.
