Assembling own watch
I have been thinking of assembling my own watch for a while. After seeing the video by Mark I am considering a GMT watch. Seagull do two movements that look interesting. The 2533 and 2557. Does anyone know anything about either of these or could suggest an alternative. (Forget Sellitta and eta, both too expensive for this)
Seagull is the leading Chinese manufacturer, yet the same gotchas apply to them:
  • No warranty whatsoever
  • No spare parts availability, not even service sheets, zero customer service.
  • Production is graded, so when you buy cheap retail you get the worse ones, don't expect performances or durability.
Have a read: http://www.asian-watches.com/2016/04/a-warning-about-seagull-st-3600-vs-eta.html
But if your purchase is based on price they are pretty much the only choice.
BTW: we have a dedicated section where most members like to introduce themselves before asking questions.
  • 8 months later...
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
