seiko 11a mainspring?
Ishima
Thank you for your speedy reply rogart. I don't suppose you know the difference between th 1104a mainspring and the 11a's mainspring? (im assuming there is one, however small, as they are under different Seiko part numbers) the other thing is, I should like to get this from a supplier if possible, for business purposes.
Just googled my way and then found boley had a number for the mainspring. 401 113. Then is googled that and found this on  ebay. Didn't do much research. Have checked if cousinsuk has any parts?
If i look on boley.de they say ersatz 03567 for 1104
http://boley.de/en/caliber/watch-movements/hattory-seiko/6924
and if i look at 11A they saye ersatsz 03567 also
http://www.boley.de/en/caliber/watch-movements/hattory-seiko/6895?q=
Then look at cousisnuk for 1104A they have a replacement  mainspring GR5458. So that must work in the 11A also.
Edited by rogart63
  • 5 years later...
Hello @Ishima, hello all,
Did you find a suitable mainspring?
I'm also servicing a Seiko 11A right now and I am unsure.
I measured the mainspring I found in the barrel as 1.6 height and 0.06 thickness; with a barrel diameter of 5.2 (maybe up to 5.5). Despite @rogart63's unquestionable logic about the supposed compatibility of the cal 1104 mainspring, the GR5458 is 1.85 high and the barrel is 6mm. That seems very large for the barrel I'm working on.... I have my doubts.
Any feedback?
Cheers!
EDIT: I found this. As you can see indicated by red, the mainspring for cal 1104A is NOT compatible with cal 11A. The parts printed in light letters are compatible, but those in bold are not.
But the question remains, what are the "official" measurements of the 401.113 mainspring...?
EDIT No2:
Based on my own measurement, I think this one is the closest match:
But still looking for clarity...
Edited by Knebo
Seiko is not going to give you an official measurement as you're supposed to purchase the mainspring by part number. then the link below has parts including two separate mainsprings of different widths. Giving you even more choices.
then of course there's the mainspring catalog
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_11A
Thanks so much for the replies!
But has become even more mysterious...
@JohnR725: Jules Borel suggests such drastically different mainsprings?? How? 0.7 and 1.1 thickness... and more crazy even, barrel diameters of 6.5 and 10?? Impossible that this makes any sense. The watchguy.co.uk link from @DrHWO also suggest the latter (1.1. thickness and 10mm barrel diameter). But it cannot be correct.
The fact: the barrel has a diameter of 6mm. I'd even have doubts that 6.5 would fit.. but 10mm: a joke.
So, I guess if I dismiss the outrageous one (on Watchguy and in @JohnR725 second screenshot), there are MS-714E and GR4428. At least they agree on 1.60 height, 0.07 thickness and lenght of 240/242. I guess I'll just try my luck even if I'm worried that the barrel diameter of 6.5 is just a bit too large (again, I measure 6).
But happy to read more of your thoughts 😛
Screenshot also from Jules Borel (note that the MS-714E is listed as the replacement for 1.50 x 110(=0.11mm?) x 420, hahaha, how??)
11 hours ago, Knebo said:
.........I guess if I dismiss the outrageous one............
My bad! 401-113 isn't listed on watch guys mainspring page. Clearly I need to leave this to the professionals!
I thought we would have fun and see how much more confusion we can have today. So for this I'm going to bestfit online and we get this. So we get the generic first and then we get the original. The only minor annoyance of the online edition is is no pictures and we don't get a better description of the mainspring but we will get a cross reference
first the cross reference of the original number of very few watches using that spring.
then the cross reference of the substitute number or the best fit number if you want
then what's interesting about the alternative numbers or the MS number is it's basically the Denison size of the mainspring with a letter for the length is brings up an amusing problem but it's not much of a problem bestfit has a different letter than we have up above but there's three springs are probably all work just fine
and just in case you don't have a listing of those numbers I've attached something with the listing and a bunch of other bonus mainsprings listed also.
Oh and if you want to worry about thing as their other dimensions that are not listed that are really important. Like the center curvature that fits over the arbor if it's the wrong size it's an issue and other mainspring this big it's going to be a major issue to do anything about it you can sometimes squeeze it for mainspring on a pocket watch if you're lucky you might not break it but on a tiny watch it better be right the first time I would look on eBay and see if you can find an original spring.
Mainsprings Cas-Kar Catalog 2018.pdf
I don't think there was anything wrong with your answer! I used WatchGuy before and I hasn't failed me until this time. Thank you anyway!!
😅 go for it!
As much confusion as you may try to create ;-), your sources and attachments are always of great value! I always learn.
In this case, however, your post is rather reaffirming, not confusing. It confirms that I should go for either of the following. If the 6.5 diameter of the GR4428 fits, perfect. If it's too large, the GR4427 will be the next best thing. With regard to the center curvature, I'll have to cross my fingers.
Thanks again!
So I can report that GR4428 does NOT fit from the washer. Too large for the barrel.
I'll be ordering GR4427.
Well well well, I got GR4427 now, and it's also not working properly.
It does fit in the barrel just fine, BUT the inner curvature doesn't work (just as @JohnR725 warned). Specifically, the size of the last/center coil is too large for the unusually small barrel arbor of the Seiko. It won't hook properly.
I've now found and ordered an NOS Seiko spring #401.113 on eBay.
Again, I'll report back.
On some mainspring you have to heat the inner coil and use rounded pliers and tweezers to shape the coils smaller to fit the arbor. A denatured alcohol lamp or solering iron will work.
Look up Alex Hamilton the US watchmaker who has has a tutorial video on his Youtube channel. Do not try to bend without heating first as it will break. I am getting prepared to try one myself.
Hey @Razz, yes, good point, I'm sure that's possible. I did something similar with a Vostok mainspring (the bridle had broken off and I just "bent" back the last bit of the mainspring to create a new bridle. It worked. Back then, I just used a normal lighter... that was sufficient and the watch is still running very well.)
In this particular case, I have already ordered an original Seiko spring and I hope that it'll just fit.
Well, getting the original Seiko mainspring made things easy. It just fits with the right inner coil for the arbor. Seiko part 401.113.
I have to boast a bit on this occasion... I achieved oiling perfection on the pallet stone lubrication. Note that this movement is 13x15mm small and that the parts are absolutely tiny.
I oiled it last night by pure feel (I don't have a microscope). Checked today and I'd say that the oil contact area is spot on. No?
The timegrapher trace is also spotless.
Before:
After:
Edited by Knebo
Is it nice when you can just show something in and not deal with the nightmare of this is a small watching getting the mainspring in is a definite issue if it's not in the ring.
Like everything else in watch repair there can be some variations. But based on the amplitude it looks like you did good and the trace looks nice and clean if for instance you only have lubrication on one side that shows up on the timing machine.Oh and regarding the timing machine it is always best to check in more than one position like dial up and down and then one of the crown positions just because but yours is looking really good
4 minutes ago, DrHWO said:
I'm still struggling with more "normal" sized pallet stones!
Oh you can always go to pocket watches where I don't get concerned about the quantity of lubrication on the pallet stones at all. Pocket watches tend to be big enough that the rules of super minimalistic or else no longer apply. Or basically for the most part I just don't worry about it other than if I get too much where is not supposed to be I take the pallet fork out the rinse it off and put it back in again and see how things look.
You're right. It seems the pocket watch is less critical.  I've just completed a Waltham 610 grade (1920, so > 100 years old) and the pallet stones were bigger than the wristwatches I'm used to. I'm not sure how long it had been seized for, but it took several cleaning steps before the accretions of brass shavings and monkey brain oil parted company with the pivot holes (7 jewels).
Edited by DrHWO
spelling error
This is actually the best pocket watch to service what you're describing. Organic oils have an outstanding property of going bad with time. The outstanding feature is the watch stops and does not disintegrate over time. As modern lubricants don't disintegrate but at some point in time may not lubricate then things will start to wear out especially a seven jewel watch. So basically it means a cleaning ok a really really good cleaning and maybe a little more cleaning and a new mainspring and you have a beautiful functional watch.
Although brass shavings in a watch or never desirable. I find a lot of times the keyless and other places where you have a steel wheel rubbing on a brass surface is where you will see the most wearing. So for things like that I just take the steel wheel and use of Pisa lapping film across its flat surface and knock off any edges that have developed over time and that seems to help at least hopefully. But yes a lot of the early keyless works there's a lot of metal on metal.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
