I wound many phonograph springs in by hand. Today I managed to wind a small ebauches movement watch spring in by hand as well. A bit tough. Only took about 5 minutes but it worked. Just to show the size difference here is a pic.
A mainspring winder is necessary when it comes to clock springs. Winding in by hand can distort the spring. This can cause the clock to be poor in timekeeping, cause unnecessary rubbing/wear to the inside of the barrel and barrel top. With the rubbing, it can weaken the spring. The same can be said about watch springs. New watch springs come wound, you can just press them in with no distortion.
There are many different types of spring winders if you are going to invest buy a good one, with watch type ones, find out if they will undertake the task of all size springs and fittings. The same goes for a clock winder.
Agree mainspring winders are the way to go. I’m attempting to build up a complete secondhand set from ebay purchases due to the cost of new sets. I’m about 2/3 of the way there with an old Bergeon 30081 set but still searching for sizes 9 to 15. Cousins sells some new ones singularly (not all) at around £45 each. Would you know any other sources one may acquire them?
Have you tried ebay? I see you are in England try auctions or even second had shops that sell tools. How about old watchmakes near you. When I lived in Lyme Regis I woul go to Bridport on market day as a stall sold second hand tools.
Thanks for the tips. I shall keep a lookout.
I have to track my spring winder down . It is in a shelved tool cabinet at my moms. I was really carefull when putting this spring in. So as to not kink it or bend it or to scratch the barrel edges I know it's a pain or even unsafe to do it that way. The spring winder I have is an adjustible one for different barrel sizes. It's an old winder.
Edited by Eckehardt
Well I could have done with one today, I went from this:
To this:
Ok, it’s a 40 year old ms but I’m not sure that it wasn’t at least partly me.
To this:
The type with the bridle on the end are a bit tougher. Yes and when they're older they can break. Depends on how they were treated. For those and any others use a spring winder. Last resort method. On real high end watches a winder is a must.
    • Thanks for the info - I'll go big on the gaskets... Wonder if anyone sells hundred packs?!
    • Looked into this some more and I believe that some of the increase in rate is attributable to the drop in amplitude after 12 hours off wrist, from 300 to 275 degrees horizontal and some is due to the lower temperature (38 to 18 degrees). I can see that approx 3 to 4 seconds a day is attributable to each. I can be happy with that.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • Hi all, I'm almost ready to make my first attempt at watch repair. My initial goals are very modest, just to get an inexpensive watch or two to work on, and take it at my own pace. I have what I think are the necessary tools on the way. A couple of things arrived already: a loupe, some tweezers, and a cheap demagnetizer. After looking at the options for oils and grease, I decided to start off with Citizen A-O2 and A-O3 oil, and Seiko S-3 grease. The Moebius was just too pricey to buy this early into the undertaking, when added to the cost of the other tools I've bought. Screwdrivers are Kwong Yuen for now, but I took the frequent advice on tweezers and bought Dumostar 3C and will probably add more DuMont later. I'm looking forward to making a start. I'll need a watch to work on, so I'm trying to line up an auction purchase within the next week. I've been mostly looking at Seiko and Citizen, and will perhaps a Seiko Crown if I can land one at a decent price.
