This literally a tiny issue, but It would be interesting to know how to deal with these kinds of things.
As you can see from the picture below, there seems to be a bit of damage to the plating of this 1969 Speedmaster cal 861. It’s very small, but how do I make sure the damage doesn’t spread? I guess I should remove all loose plating, but should the surface be treated with something too?
There was some greenish goo over the area when I first opened the watch, could it be a reaction or another watchmaker that put something on it?
The green goo is usually the oxidation of copper.  Most copper compounds are green or blue green.  Anything you can do to prevent the surface from contacting the atmosphere should stop it.  I don't know what works for watches but for other things sometimes people use varnish or wax.
That is probably corrosion due to a bad gasket or something done by a previous watchmaker. I don't think it will spread. But you should need to look over your gaskets. The little i can see i can see that it's in bad shape. Maybe have a service done or at least a check.
Omega has coating called rhodium.
Thank you for the replies.
i wish I had taken a “before” picture, but I guess you are right about the stuff being oxidation. A surprisingly large amount perhaps, but it would match the description.
Yes, the gaskets need to be replaced for sure. But do you think there is something that could be put on the copper to prevent further oxidation? I mean, it should be something that stays put.. :)
Have seen some rhodium repair on cousinsuk. Have it in my watchlist but never had come to test it. It's called magic rhodium. Someone here maybe has tested it? https://www.cousinsuk.com/product/magic-rhodium?code=R49276
    • It might be a good idea to clear out all your browser caches (this should include any DNS caching). I might also be inclined to recommend Roy from the IT crowd’s answer to everything - Have you tried turning it off and then on again? 🙂 But seriously - sometimes a phone reboot can help. If problem persists then you can then know that its an upstream issue rather than your device.
    • Hi, I'm Marcel (51) from The Netherlands. I recently started my first vintage watch project. Before that I mainly worked on the necessary basic knowledge with the help of videos, forums, such as WatchRepairTalk, and other online information. So today the step to also become active on WRT. I hope to learn a lot from you. Best regards, Marcel
    • Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.  TZIllustratedGlossary.pdf Watch_tools_tipps.pdf
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
