The Cousins web site document download section has the data sheets for this movement to download.
Just now, WatchMaker said:
A really useful source of information is Christian aka watchguy.co.uk
Check out https://watchguy.co.uk/cgi-bin/library?action=show_brand&brand=Roamer and you'll see he's worked on three 522's and taken photos along the way.
I've worked on a Limelight and Searock with 522's in the recent past so may be able to help in the unlikely event you hit an issue.
thanks for that.should help.if not i will get back to you Watchmaker.Bernie.
  • 11 months later...
i need a spring for the date selector?.do you know where i can source one?see pics. i think the part no is 3480 (440)?
Hi Bernie
I think the part you need is actually # 2575 i.e. the date jumper spring. Part # 440 (3483) is the yoke spring used in the keyless works. I expect you have the parts document for the 522 already but if not you can download one from here: https://www.cousinsuk.com/PDF/categories/2348_MST 520 512 522 523.pdf
If you concur that it's part # 2575 you need then Cousins do one at £5.95 if you search for item number MST5212575.
As a P.S. ...
It's a frustrating truth about watch repairing that there are small 'commonish' parts that must cost pennies to produce but pounds to replace. Your spring is a good example as, with postage and VAT, it will cost over a tenner to replace! But it's just a super-simple U-shaped spring! Grr!
There seems to be a real market out there for a supplier to produce a set of small date jumper, click springs etc. I'd buy them! Cousins do do a set of generic Shepherds Hook Springs (item W36105) but they're all pretty large. It might still be worth adding these to your order as there may be a handful in the selection that could come in useful in the future...
3 hours ago, WatchMaker said:
As a P.S. ...
thanks watchmaker.i realised while searching later yesterday that it was indeed the date jumper spring and it is no.2575.i already have shepherd hook springs so i will have a look at what i may need so i can justify the postage! like you i cannot understand why some bright spark has not thought of manufacturing these "common" items.they would make a fortune.again thanks for your help and merry xmas.B.
    • By coned do you mean it sits proud of the barrel before you fit the lid?
    • Hi all, Might a posit a theory and people can chime in and tell me if I'm barking up the wrong sycamore: If a mainspring is a bit coned and returned to its barrel for reuse, is it less likely to slip when the spring gets to fully wound?  For a bit of background: Slava 2427, barrel walls greased with 8217, six dots evenly spaced around each of the barrel walls, then smeared/ spread along the wall before popping the springs in.
    • Always in love with watches since I was a kid and with fixing things as I grew up. 10 years ago I bought my first mechanical watch, the Invicta Pro Diver 8926. Recently it started not keeping time at all and when I made an attempt to regulating it I messed up the balance spring. So I decided to go for it and do the following: replace the NH35 movement in it and get the parts to try to fix the original movement. Turns out I should have gone for the balance complete, I just purchased 2 balance wheels. The first one was a disaster, the second one I was able to attach to the stud holder and even install in the watch, but I was definitely doing something wrong as the hairspring got tangled and bent out of place by too much. But by now I know how to install the balance complete. Also decided to change the bezel insert for a green one to freshen it up. But now I'm thinking about either going back to the old danged up insert or keep replacing parts (sapphire glass and another dial, since I lost the "Invicta" letters while cleaning the dial from dust). The invicta has actually sentimental value due to it having seen me go through shit in my life, I'm never going to part from it. I am just debating whether continue freshing it up or putting it back to it's "original" status with all the scars of the old bezel. Parallel to that I made a "build" (watch on the right), putting together a NH34, dial, hands and putting it in a case. It was actually my practice watch for the hand setting. The seconds hand was a terrible nightmare, when I finally got to insert it then the watch wouldn't start. Turns out that the paint job was a bit too thick, shaved a lump with a razor blade and it solved it. Installing the invicta hands on the other movement was a walk in the park in comparison, I'm very happy I practiced with an "aliexpress watch" first. But the thing is that I got it down to around 0.5ms beat error and +6 s/d, so I'll probably gift it to a dear friend as a "tool watch don't baby it at all". Anyhow, cheers to you all!
