Hi all
Got this Seiko 7t32-6a5a a while ago for peanuts.
8nq7R7b.jpg&key=714aa83855c94161a84bfc5e04162fe80778249c3a2e08a079bb0733f43a1e62
At first I thought it would just need a good clean up and maybe a circuit block from a trashed donor but when I disassembled it, I soon found out the reason for the sticky pusher.
Nope, not DNA but a careless user...
Can you see it?
ybpWYo0.jpg&key=e52cdc6f3c6ae535d90a258b1ab31be6126010572f1ca71d7d87495d2e20ae34
Bit closer
HyHozEo.jpg&key=3272b61f5c211ec7f86521df43f6c59373ad5ab34335fe6d426bfe14fbf649ad
The snapon casebacks have relief cuts to accommodate pushers and stems but the previous person to "work" on this was not very careful and ended up crushing the tube.
Can this be remedied or is the case trashed?
2 hours ago, ro63rto said:
Hi all
Can you see it?
Bit closer
That should be fixable. Either ream or use a something to get it back in workable shape again. As long as the gasket doesn't get trapped and the pushers works it should be fine.
Be sure to post your results as well please[mention=224]ro63rto[/mention] ! And is this the same Robbie I talk to elsewhere?
I certainly will and yes,
It is I, Robbie [emoji4]
    • I see. And is there a possibility to convert it to a springless system by replacing it with a standard split stem model?
    • Sharpening gauge.   I found the easiest side to do was the safety roller as the roller table laid flat on a block provided stability.  The other way requires a specific stump for the roller and pin to sit in, but may also grip better way.
    • Yes, the problem isn't so much with the 'background' radiation but inhaling or digesting loose flakes and dust that can become airborne.
    • The spring is so the crown pops out to the winding position when unscrewed.
    • Radium and the horrible story of the Radium Girls scares everyone - But there is also a lot of paranoia here.  I did a whole bunch of readings on a watch with Radium lume recently. My Geiger counter read 2µsv/h through the crystal with the sensor part of the Geiger counter right on top of the watch.  This measurement dropped off to the normal background rate of 0.18µsv/h as soon at the Geiger counter is just a few cms away. Measuring from the back of the watch and there is virtually no increase.  The rate went up to 5µsv/h from the dial and hands when the movement was removed from the case. To put this in perspective a Frankfurt to New York flight would give you about 50µsv of exposure and a chest x-ray about 100µsv.  Norwegian labour law states “The limit value for workers over the age of 18 years is set to 20 mSv per calendar year.” - that is the equivalent of 400 flights across the Atlantic! I will however point out at this point it is important that you don’t ingest the radium from the watch! One of the worst things you can do is scrape the radium off the dials and create radioactive dust that you could breath in! That being said… If for each radium lumed watch you work on you spend 15 minutes getting the movement out of the case and the dial and hands off and then another 15 minutes at the end putting the dial and hands back on your exposure would be less than 2.5µsv  Once you have the hands and dial off they can go in a box and put safely out of the way (probably good practice for any watch!). I believe the risks are negligible If you take precautions such as wearing a mask and gloves and wiping your work surfaces down with a damp paper towel and disposing of the towel, gloves and mask once you are finished
