Hi all, hope you are all having fun with your projects - I was till I hit this snag. I am working on a wee ladies movement and all was going well until I got it back in the case! It was running fine but the crown and hand setting were not right. I guessed it might be the setting lever and when I got the dial off it turns out I was right. The setting lever was broken so stripped out the keyless works, cleaned and lubed, replaced the setting lever and put the dial and hands back on. Problem solved just need to re-case. At this point it was running a treat again and keeping good time. Put it in the case and it stopped running. Maybe the minute hand is fouling? Off with the bezel - no different. Took it back out of the case to inspect and I can now see that when the balance swings the escape wheel is not advancing. Any suggestions as to why not would be greatly appreciated?
Looks like it has overbanked and the impulse jewel is now out of the fork. Other possibility is broken impulse jewel or pallet pivot. You need to take escapment apart to check.
Edited by jdm
I had a similar fault on a gents Certina. The escape wheel had no drive. I cleaned oiled and re assembled the gear train and I think the fault was the 3rd wheel sticking. Fine now !!. Hope this may help
Cheers jdm, oh heck! Not the answer I was hoping for, but very very helpful. Presumably, in order for it to over bank you are suggesting that one of the above must of happened? At least I know what to look for. Thanks for sharing your knowledge.  It would help if I could see what I am doing :startle:
It may well help, that I can cope with... haha! I was not planning on stripping it all down since it was working ok and it is about the size of a penny,  but hey ho, it is all good experience. Many thanks for the input.
    • I am sure you agree that,    " physical reality is actually made up of structured information "  which defines the states energy may  realize in prescribed  states.      Universe is committing suicide then most of its functions stops, but what we know as  gravitation remains, thus ( as he concludes)  gravitation proves of no essence  for actualization  previous functions universe used to work according to.   No doubt mathamtic systems man has deviced  is basic and not neccessarilty correct . But if universe is informational,  its also computational.   Then we have something thats has no essence and computation systems indicates it as virtual.
    • Oh that is lovely, thank you. I also just cracked the crystal and lost one of the shock absorbers, so its gone in the separate baggy of 'maybe-one-day' 😄 I did learn the valuable lesson of not disassembling the shock absorbers. My next one is a Zaria 1509B. I think this one I'll take a bit more time with cause I'll need to source a couple of bits. It's also scary teeny.
    • More data on the oscillation tests: Vertical: 15-20 seconds…Abysmal Dial up: 1 min 15-30 seconds Any thoughts @nevenbekriev @JohnR725? My next thought is to oil the balance jewels to see if that helps. It’s certainly one major thing left that I haven’t done.
    • Hi. Once the pins have been withdrawn the brace let comes apart, never had a problem with these.
    • Hello and welcome to the forum added the racketa 2603 sheet incase you don’t have it. 4328_Raketa 2603.pdf
