Where is ratchet mech
Boogi11
Hi all. I have wanted a jump watch for ages and picked this up cheap . It won’t run, I think it’s dirty which I can sort , but also I can’t see the ratchet for the main spring . It has failed or is missing , any ideas 961aba1e0fb08f6cd7c1cdf224c7ac83.jpg
Looks like it's missing, or is broken...Baumgartner 582. I might have one in spare parts...but show a pic if its broken and the piece is under the wheel anyway.
J
5a21ac45d41b7_ScreenShot2017-12-01at2_22_22PM.png.9f547f86c14d5f3b9ee1a8a5d4d493e6.png
J
Hi, sorry for being thick , but I have the gear, where exactly does the click spring sit ba774c4439907cb5961c9ed56c9056fb.jpgaaced289e16ccfac3daa6eabdb07a1fd.jpg
Its missing then. The click spring sits underneath the ratchet gear and you would see it in this place:
11 minutes ago, Boogi11 said:
Congratulations. Step one has been successfully completed. Now you know what you need to replace, but that doesn't mean everything else is OK, but let's hope so. I'll look to see if I have a click spring for the 582.
J
Joe
J
Joe
I’ll let you know in a bit , how does the click spring work please , even though I know what it looks like I can’t figure it out
This one is broken. I found a picture of another one that is also bent but still complete:
5a21bfdf3e5d0_ScreenShot2017-12-01at3_09_07PM.png.ec85b6668b81ed2ecde99763e9a1c9c2.png
The click spring holds the  ratchet wheel that keeps the arbor and mainspring from uncoiling after you've put power into the mainspring...i.e winding the watch.
J
Most watches have a 'click' that locks the ratchet wheel from allowing the mainspring to unwind between winds and in general running, and a separate component, a  spring that pushes it into place to do so, this is a click and spring in one component.
Yes thanks for pointing out that fact. This is a click and spring in one.
J
J
Well boys, this is a momentous occasion , after recking about 8 raketas , I have finally stripped a non working watch , cleaned rebuilt and got it working (still need a ratchet) this is so satisfying , wanted a d5fbbf08b83fafa116f5698c8ed0bc08.jpgjump watch for ages and now it’s my first repaired watch
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
