Can anyone clarify if this is a genuine or conversion? I'm thinking of buying it.....
serial number 1-714271 M9
I have no reason to doubt the seller, it all seems legit but someone might say otherwise!
Lee
Hi Lee, I'm not an authority on anything much less in watches authenticity but it looks like a regular Accutron to me. One thing is certain, it is beautiful and very well preserved! Even if you decide not to get it, I congratulate you for such a nice find!
Cheers,
Robert
so you saying its a converstion, not a spaceview? if so (just curious, as I've brought it now anyway!) what makes you think that?
Lee
No Lee, sorry, I probably didn't say it right. I said I'm not an expert and much less in this type of watches but I've seen this model -- which is not normally in such a great shape by the way, for what I've seen -- but I wouldn't be able to tell either way: spaceview or conversion.
Accutrons are fairly rare in my circle of watches -- maybe not so much on this side of the pond as more like in my region so to speak -- so to me every time I see a well kept, exhibition type like yours, meaning showing the circuits and all, I really enjoy them. I haven't simply researched much on them yet. Sorry if I made you believe it was one thing or the other and pardon my ignorance on the subject. I wish I could help more.
I found a great website this afternoon ( http://www.accutron214.com/ ) which makes be believe
  • Due to the case back not having “waterproof” or “water resistant” it is a late 1969 version.
  • In 1969 Bulova introduced a new series of Spaceview watches due to sales lagging behind more popular 218 models which included wide gray chapter rings, they where very popular and sold well in 1969 & 1970.
  • In 1969 the orange second hand was introduced
  • The Case#770 was a swiss spaceview only.
So to the best of my untrained ability I believe this to be genuine.. can anyone back that up for me?
And by the way 1969 is my Birth year & my chosen preference for watches I buy!
Edited by Lee
Hello Lee,
The dating for the Bulovas is quite easy the first ones were A9 - 1949, then L was 1950 with a number ie L9 = 59, M -1960 ie M6 = 66 and N - 1970 ie N5 = 75.
In my experience cases and Movements are often swapped out especially with the price of gold currently.
For a proper check refer to http://members.iinet.net.au/~fotoplot/accspace.htm
Cheers,
Vic
Edited by Vich
Hi,
   Thought I would jump in here for a bit. Your spaceview does appear genuine. The converted one typically do not have the chapter ring. The ring is made to fit the case and will not fit into a regular 214 case. Some people have taken to cutting the outside part of 214 dials off to make chapter rings but you can easily tell the difference. On these when you remove the movement from the case the ring also will come out. A factory spaceview ring can only be removed by removing the crystal. The original spaceview case also does not need a spacer ring installed to make up for not having a dial.
    Now that I have said all that I would like to include that many of the converted spaceviews actually came from the dealer that way. To keep up with the demand for the spaceview Bulova developed a conversion kit so that their dealers could build them in their stores. This kit typically consisted of a mr 401 spacer ring to allow removal of the dial, a crystal with chapters printed on it and a set of white alpha hands.
Charles
  • 6 years later...
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness oil in-between . You want a short answer now,  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
