How do I start on this
jnash
Any tips , start from the inside and go out , or is there something that can be done from the collet ? Any tips before I start..
I would rather it all be tangled up as at least I would be able to deal with it !
Thanks in advance
Sent from my ONEPLUS A3003 using Tapatalk
Personally I think I'd rather have this than having a hairspring all tangled up.
So an interesting book is "Bench practices for watch and clockmakers" by Henry B Fried Has a nice section on what to do with hair Springs that don't quite look right. I would suggest though practicing on a practice hairspring first. But if you lack of practice spring you could try just be careful not to pull too much. So a couple images out of the book.
From the photo, the helix spiral does not look uniform to me. You might still have a small kink or two along the spring. The spring should flatten out if you follow Fried's instructions. A few gentle attempts are much better than one gorilla one. Done correctly, the change in the radius should be negligible.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
